Hi
I`m new to dvd writing and have just got a panasonic ld 311 1x dvd writer.
I know that if I use 4x discs I can still only burn at 1x but will they work or do I have to stick with 1x discs.?
The reason I`m asking is that my local shop is stocking 4x discs only and not 1x for the same price.
I tried a 4x disc and it failed to burn with nero, I have had no fails at all with my 1x datawrite discs.
I don`t want to buy a load of discs to find that they won`t work.
Thanks if anyone can shed some light on the subject.![]()
Depends on the brand.
My LF-D311 will not burn Optodisc 4x, errors out at ~25%. Poor results with Lead Data 4x (DupEz, Accu, PioData), and poor results with Samsung BeAll 4x.
Ritek 4x and Prime 4x burn just fine.
I've used both A127 and A128 firmwares. No difference between the two.
How does HD Writer do it?
By OldNick in forum Authoring (DVD)Replies: 7Last Post: 11th Mar 2012, 19:57 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
Best AVI Writer?
By ouxch in forum DVD & Blu-ray WritersReplies: 13Last Post: 5th Jan 2008, 02:31 -
Writer burning discs erratically
By uNderdog_101 in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Nov 2007, 14:08
