I have been trying to convert Xvid to DVD but with no luck.I have posted a couple of questions and tried to follow the instructions i have been given.But i just aint getting nowhere.could i have my codecs setup wrong or something daft like that.I really am lost,it doesn't matter how i do it the audio is out of synch.Any help would be great cheers![]()
Ever seen the Devil in the pale moonlight
The ffdshow codec/filter will decode just about every mpeg-4 varient.
Download and install the latest alpha ( fairly safe ).
http://sourceforge.net/project/showfiles.php?group_id=53761 -
do i need to un-install any of the codecs i allready have or just install the new ones over the top?
Ever seen the Devil in the pale moonlight -
um, you can use vdub, save the audio as uncompressed, then use tmpgenc to change to dvd compliant mpeg and use the uncompressed audio as the source (and recompress it to cbr mp2)
so strip the audio then encode the video on its own and then join the encoded video and the uncompressed striped audio together.If this is what you mean what do i save the audio as when i strip it with Vdub?
in vdub, go to full processing, then click on audo> compression "uncompressed (pcm)". then file > save as wav.
Effect? i dont know what it's called
By upper in forum Newbie / General discussionsReplies: 14Last Post: 15th Mar 2009, 03:33 -
New BR technology we dont know about ?
By ian curtis in forum Software PlayingReplies: 6Last Post: 30th Jan 2009, 23:02 -
Dont forget your roots
By seijin_ in forum Off topicReplies: 1Last Post: 10th Dec 2008, 22:03 -
Ok. I'm not new to VirtualDub but there are things i still dont know about.
By Balefor in forum Capturing and VCRReplies: 2Last Post: 14th Aug 2007, 18:59 -
Why dont they make better movies?
By NICEBUD in forum Off topicReplies: 7Last Post: 10th Jul 2007, 16:39
