I converted a divx movie to vcd.. but no sound is present in the final file even though system video + audio is selected.. so now I'm assuming I would have to convert the audio from the original divx seperately.. is that acceptable even though the movie was converted with audio + video, or will it only work when the movie is converted in system - video only? does that make sense? Also, is it normal for TMPENC to do this? I swear it did video and audio perfectly last week.. now nothing for audio? strange..
i have an amd thunderbird 1ghz, sound blaster live value, 384 mb ram...
Thanks!
How about this, first, open TMPGenc, file\mpeg tools. Select De-mux, open your MPG file, extract the video to a seperate file. Now, open the DivX movie (if possible, not sure) demux the audio to a file, normalize the audio and then convert it. Then mux them together =) That should work.
DivX 7 Pro mp4 to Divx conversion
By mkochsch in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2010, 02:22 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 08:12
