Hey everybody i have got a big problem: creating a DVD. first let me tell you what media and software i am using.
MEDIA
Verbatim DVD+RW
SOFTWARE
Ulead Moviefactory
now my problem is this. i have three VCDs and i did these steps:
1) Used Isobuter on the files for all the three VCDs
2) Ran Moviefactory and added the files to the list
3) Created Menus and stuff (not significant i guess)
4) Tested it (worked)
5) On OUTPUT SETTINGS, i only checked Record to Disk
6) The recording speed was MAX and the burner drive was correct
7) In BURNER ADVANCE SETTINGS, i unchecked Quick Eject
8) Then i hit OUTPUT
9) It was doin its thing and it was taking a long time so i let it do its thing over night
then there was an error i forget what it was but i am gonna try again and then tell u what the error was. if i have done anything wrong please tell me. or please just help me out. thanks.
Results 1 to 25 of 25
i see that i did one thing wrong, the DVD+RWs case says 2.4X and i hit max so i already changed it and am awiating the results, please help me ok everybody thanks.
i think it would also be helpful if i told you guys that when using Isobuster from VCD to MPEG, the files didnt come out as MPEG maybe that is the problem, can u tell me how to fix that? anyone?
Originally Posted by skip2mylou
BTW, Don't you need to change the audio from 44.1 to 48 KHz?"Art is making something out of nothing and selling it." - Frank Zappa -
I WAS ABLE TO DO THIS BUT I DONT KNOW HOW TO DO A CERTAIN PART IN STEP #3 CAN ANYBODY HELP?
Use Isobuster to copy the video from all the SVCD/VCD to your HD (If you already have your files in MPG or CUE/BIN format you don't have to use Isobuster) .
1. Choose your CD/DVD Drive
2. Locate the MPEGAV(VCD) or MPEG2(SVCD) folder
3. Select the mpg or dat files and right click and select Extract but filter only M2F2 Mpg frames. Save as filename.mpg.
how do i save the file as .mpg after i Isobust it?
and what does this mean: SVCD/VCD to your HD
and how do i do it?
please help. -
zippyP.
U R probably right but i dont know how to do that. do u know, can u tell me? -
For step 3: When you right click on the .dat file a box pops up and you select "extract but filter m2f2 only frames" and when you do that another Extract File dialog box opens up, in that box you select where to send your extracted file and you can give it a name (in the file name area) with the extension .mpg.
SVCD/VCD refers to either a Super Video CD or Video CD, depending on which type of disk you are extracting from, and HD is the hard drive (or hard disk) in your computer. That's what Isobuster is doing, converting the .dat to mpeg and saving it to your HD.
Good luck!
P.S. The second step in the guide says that Moviefactory converts the audio for you so you can disregard my comment about that."Art is making something out of nothing and selling it." - Frank Zappa -
You're wlecome!
hey zippy i did what u told me. so far i have Isobusted 8 files and renamed them .mpg and stored them in a folder. now what do i do?
Originally Posted by ZippyP.
I believe you have done Step 1, keep going.........
Good luck!"Art is making something out of nothing and selling it." - Frank Zappa -
hey zippy my man thaqnks for the help, all i had to do was change the audio file. its doin its thing now so will let u know how it turns out, thanks again.
Cool, glad to help!
yo zip we have a little problem, i had let Moviefactory do its thing, then it was like stuck on FINALIZING VOB... for like some time, i dont know cause i had to go somewhere, and when i came bak, i said this in a little wondow: You need a CD-R/RW to burn a (S)VCD disk image file. Please change the disk first, then try again.
wat does this mean wat do i have to do? i followed the steps perfectly. -
trust me that is what it said
but i found a way to burn DVDs
with instantcopyDVD. but
i would still like 2 use
moviefactory, can u help me. -
Read that error message again. Pay particular attention to the first sentence, and to the type of disk that you have in the drive. Then perform the suggested action in the second sentence of the error message.
ok i read it it says the same thing, the disk that i have in the drive is a verbatim DVD+RW. can uhelp me?
Continue reading the error message and cheching your disk TYPE until you figure it out.
I got error messages too when I tryied to burn directly with moviefactory. Try having it creat the video-ts folder instead and burn with you dvd burning program. this worked for me.
Hey FT shark, that is an excellent idea thank you s much, i will try that and tell you the results. thanks again.
JCOAJ!
The error message states you need a CDR/W. You have a DVDR/W in the drive.
You need a blank CD, that is, NOT a blank DVD, to burn an SVCD image.
I would highly recommend some time spent reading some of the guides and documentation files available. -
@ everyone especially FTshark and ZippyP.
thanks everybody for helping me out with my problem. thanks to everybody i was able to find a way around it
. i would especially like to thank FTshark and ZippyP. for really giving me different points of view
. they really made it able to overcome the problem so thanks again.
P.S. hey FTshark, the method u insisted worked, but you probably already knew that, but thanks anyways.
