whats up guys its been awhile since i've posted on this site
I was the creator of the largest THREAD in VCDHELP.com history
anyway i wanted to know that if a DVD player doesn't support vcds or svcds
but they play dvd+r
will it work if I burn a vcd or svcd onto DVD+R media
basically ive sort of forgotten if its considered a vcd if its burnt to a dvd media
thanks
y2flyy
Results 1 to 11 of 11
I would read the guides and check the database to the left <----
*All* of your questions are answered there or have been answered many times in the forum already. -
i understand about the guides snow ive been using this site forever
i just got a dvd burner and now i am utilizing and exploring things that i normally could not do
i looked through the guides and i see nowhere where its stated the answers to my question
i think it would have been more sensible for you to answer my question and then rant off about the guides like im some noob
anyway if anyone care to answer my question w/o negativelty
i would greatly appriaciate it
y2flyy -
Hmmm.... not in the guides?
https://www.videohelp.com/author
About 1/3 of the way down the page. -
uhhh well thanks snow i sort of stand corrected
but i had read over that but it didnt answer my question directly
so i guess that i have to convert the mpeg1/mpeg2 file to dvd-format
for it to work on dvd players that do not support vcd/svcd
thanks -
You can also check the DVD player database for DVD-VCD and DVD-SVCD compatibility in specific players.
Try this: https://www.videohelp.com/vcddvdr.htm
and this: https://www.videohelp.com/svcddvdr.htm -
thanks a lot yall now thats the love i was looking for
i went to the specific dvd player which is a Broksonic DVCR810
it says it doesnt support dvd-vcd or dvd-svcd
so what i should do is convert the mpeg1/mpeg2 to dvd to get the movies to play correct????
y2flyy -
Remember that vcd @ 29.97 fps IS part of the DVD spec, even though 23.976 is not ( those PAL people get all the breaks
Yes you will have to convert all of your video to mpeg-2 at 720x480 or 352x480 DVD compliant.
Or you could get a DVD player that supports everything, with the prices these days it may save money and agrivation in the long run. -
thanks alot snow
actually its for a friend who wants to watch some o fthe movies i make
i have an apex 1100w
i love it plays everything
Newbie that needs answer to a question: Transferring videos to a Mac?
By PlatS in forum Newbie / General discussionsReplies: 11Last Post: 10th Nov 2010, 23:28 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Dumb question, but should be easy to answer :). Re DVD Flick high quality
By cognus in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2010, 23:43 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34
