Results 1 to 9 of 9
  1. Okay, I encoded this VCD, and it took almost a full day to do (slow computer I guess). But I stupidly forgot to trim the first bit of the video. So now I have an MPEG1 file, and I need to trim the first thirty seconds off of it. Is there a quick way to do this, or do I have to edit the original .mov file and re-encode it?
    Feb 2003
    Bloomington-Normal
    you can use MPGTX to trunacate the mpeg file cutting off the first thirty seconds.
    http://www.biermann.org/philipp/mpegcut/
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    there is an easy way
    mpgtx wrap is a mpeg cutter/joiner.
    I believe you can just say something like [-1M] to tell it to chop off the first 1 min or [1m-] to do the last 1 min. It will give you examples of this in the window and you type it in the special commands line.
    Or ffmpegx.
    Not sure if the newest version still has this, but you can cut by min with the TOOLS option.
    Canada
    Can't you just open the file in quicktime and use the selection triangles on the bottom to select the first 30 secs, and then hit clear?
    I know MPEG uses key frames and all that...but I'm sure i was able to do this before....
    It would be much easier. That's about it. If I'm wrong on this...I'm just gonna pretend I'm drunk, ok?
    -kami
    -kamikaze
  5. Member galactica's Avatar
    Jan 2003
    Last i tried to do any "cutting/pasting/clearing" on a mpeg file with quicktime pro all the options were greyed out.
    I dont think it does.
    but then again, its been a while since i tried, maybe the newest of new updates makes it so it will.
    either case, it can be done.
    Feb 2003
    Bloomington-Normal
    quicktime, no... it cannot be done. Not with MPEG files.
  7. Member galactica's Avatar
    Jan 2003
    yea i was 99.99% sure it couldnt be done.
    mpgtxwrap or ffmpegx is what you need.
  8. Thanks guys. Once again I am indebted to you.
  9. Member galactica's Avatar
    Jan 2003
    no problem.
    (i think its safe to say ZeroSix would say the same thing)
    Hey guess what, I just turned 1000 today
