I just encoded a home video yesterday using TMPGE to SVCD format, but now the film is "square" ???
I want the movies to fill a normal 4:3 television screen. is this because the svcd resolution is 480x480? it looks like shit
someone please help
thanks
bmwstylz
when you play it back your dvd player it will stretch it out ..
see the svcd info on the left and you will see this is normal ..
if you use powerdvd or windvd on your pc - they will also stretch it out ..
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
any good "my movies" plugins for Windows media Center?
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Jan 2011, 14:47 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 15:00 -
Burning my first DVD home movies with Pinnacle, "disc error" on D
By tony777 in forum Authoring (DVD)Replies: 2Last Post: 13th Jul 2007, 22:07
