hi
i have a modest system (2.2ghz amd xp, 1 gig of corsair memory, 9700 pro, epox 8rda+ board, (using on board sound) but when im capturing something from the tv, my card is dropping frames like they are going out of fashion.
I have a Hauppauge Win/TV 878/9 model (if that makes any sense!!) and i have had this for ages, but only started using it today again.
trying to capture off of the tv (music videos for example) regardless of what res, sound quality i try and use, when i play it back, i get sound but no video. i think on average im loosing 66% of the video, which isnt good at all.. this is why i feel im getting no image.
can anyone recommend me a better capture/tv card for my pc setup, as im really not sure what to get that wont drop frames and wont cost me £1000 to buy.
if i said would a £100 be enough to spend on a card, could someone, (anyone???) give me an insight to what i might be able to get please? i might be swapping boards at some point (to a 8rda3+ so not much change at all, but another Xp1700, certain type of one anyways will be used.. hopefully it will be faster than the one i have now..) but thats about it..
do i need anything more for my pc or am i ok spec wise?
i thank anyone that replys, best wishes to all
im using the one that came with the card itself.. is there an update that might help me out or do i really need a new card?Originally Posted by fmctm1sw
i have heard that firewire is the best way to capture...
i think the drive is a year 2000... maybe something to do with the millieum bug?
on the cd its got the version 4.6.. is that good or bad?
also when i was having problems with getting the sound, i was getting a 'perfect' capture without it, no dropped frames at all. would that really make such a difference? im using windows xp pro with service pack 1a
Few Questions on Capturing and my Tv Tuner Card.
By techspark in forum Capturing and VCRReplies: 18Last Post: 15th May 2011, 15:28 -
Card for capturing HD Component Signal
By peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 10:42 -
Capturing VHS to ALL-IN-WONDER Card
By Smack2k in forum Capturing and VCRReplies: 6Last Post: 2nd Dec 2008, 10:20 -
PC video card for capturing HD source
By pglenn in forum DVB / IPTVReplies: 5Last Post: 23rd Mar 2008, 20:26 -
Build-in or separate video card for TV and capturing
By DeafBug in forum ComputerReplies: 3Last Post: 16th May 2007, 17:03
