I'm reasonably new to this game so I'd like some advice from you 'seasoned pros' please. I use a Ti PB 667 with Combo drive. I have a little experience in creating VCDs SVCDs using ffmpeg and MMT, then Toast 5.2.1 to burn.
I spend a lot of time travelling, giving presentations and training sessions. I need a portable solution for DVD creation when using a DV cam away from base, then leaving a finished DVD with the audience.
I've just purchased an external La Cie U&I DVD +- R/RW drive to provide archiving facilities for Macs and PCs. This version is cross-platform (and cheaper in the UK) than the Mac/Firewire only bundle, but doesn't come with CaptyDVD.
I have access to iDVD install disks that came with a Superdrive iMac (but I can't really carry a 17" lampstand on an airplane).
What is the most convenient way for me to create simple DVD's, playable in a standalone player, without buying DVDSP which is overkill for my needs?
GoodOriginally Posted by pglock
http://ka.ws17.arena.ne.jp/en/products/software/capty_dvd_vcd/download.htmlOriginally Posted by pglock
to download CaptyDVD
What is the most convenient way for me to create simple DVD's, playable in a standalone player, without buying DVDSP which is overkill for my needs?[/quote]Originally Posted by pglock
Try CaptyDVD. Another option would be to install the iDVD onto your powerbook since you have the burner now. However, im not 100% sure it will work with an external burner (can anyone confirm this?)
for some reason im inclined to say it wont. [Does your external burner with with finder burning or with iTunes burning? If it does, then iDVD should work?]
but you could always use iMovie, export to iDVD and if the burn is good with your external drive do that.
Otherwise, you will have to use Toast to burn the DVD once you get it exported as either a image or a VIDEO_TS folder. -
Thanks for the wise words. The drive is recognised by iTunes, I'll try loading iDVD tomorrow.
Sorry to be so dense, here's a follow on question. Just in case iDVD doesn't load, I've downloaded CaptyDVD, it asks me for a serial number when I try to run. Is there a free version or a way of entering the serial number of the dvd writer to unlock the software? -
Update: Following advice on another post, I found the full version of CaptyDVD at: http://webb2.pixela.co.jp/download/mac/dvd/CaptyDVD114_osxfull.sit
I installed the Japanese version then applied the English update from the site you gave in previous post (above).
I'll play with it tonight.
Questions about DVD creation
By downhilljon in forum Newbie / General discussionsReplies: 22Last Post: 6th May 2010, 15:56 -
Newbie needs help - wmv to DVD and iMovie
By Jeff555 in forum MacReplies: 7Last Post: 16th Mar 2009, 15:27 -
Questions about DVD importing and menu creation
By Reading Bug in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2009, 15:24 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49 -
Newbie - standar configuration for iMovie Dv
By enzofsilva in forum ffmpegX general discussionReplies: 3Last Post: 24th May 2007, 12:07
