this might have been asked before but i couldnt find it in searching the forum. How can I get a two sided dvd, for example, special features on the second side, onto one dvd-r. What would be the procedure???
Results 1 to 10 of 10
Yikes.
Not an easy task my friend. Hardly worth the effort, really. The main problem is, you've got two sets of menus for each side, and you want them to basically "mix" together, so you can access all the special features and still be able to play the movie, etc. It's a rather crazy process...something to do with basically mixing two VIDEO_TS folders. You've got to create entirely new menus..
Bah! I know it's not what you wanted to hear, but f*ck the extra features. If you really want that crap, buy the DVD. The amount of time you'll spend working to get that onto one DVD could easily go to flipping burgers at a local Mickey D's and earning the cash to buy it. At least then you'll be doing the "honest" thing.....whatever.
Good luck -
As kamikaze said, for you to get one menu for both will be time consuming, doable but time consuming.Originally Posted by smot
also, if its the type of disk im thinking about, its usually the same movie files but one is WIDESCREEN and the other is STANDARD.
So there would not be a point really other than getting both formats on one side.
You could do this, but you would loose the menu and extras, and have just movie copy with chapters and subtitle/audio selections.
But they would be split by chapters. Such that widescreen would be chapters a to b and standard would be (b+1) to (a+b)
If they are different video material, and you dont care about the menu's and extras its doable also. Using the same method where the first disks's video informatoin would be chapters a to b and the second disks info would be (b+1) to (a+b)
if you want to know how to do this, look for teh 2 dvd to 1 dvd post. its all clearly spelled out. -
There are some movies that are just continuations of the film on the other side of the disc... One good example of this is Goodfellas. There is no "widescreen" / "fullframe" version. The movie just takes up both sides. Its a real pain having to switch sides I agree.
The best way to do it is like this:
Use the program 0Sex and extract the mpeg file off the disc as a program stream. Do this for each side.
You will end up with two .VOB files.
REname the .VOB files with a .MPG extension.
Use MPGTX to join them.
Use MPGTX to Demux them. This will fix any timecode errors.
Using FFmpeg, Select the Video Stream and the Audio stream in the TOOLS tab and tell it to MUX AS DVD and to POST PROCESS and author it as a VIDEO_TS Folder.
run your resulting VIDEO_TS folder through DVD2ONEX.
This will give you a DVD with less quality than the source and no menus, but you have accomplished what you set out to do.
Hope this helps. -
ouch,
thanks but like you guys said, too much for too little, i can deal without the special features. thanks again -
its fun to try. id recommend it. It made me feel quite powerful actually
HA take that 2 dvd! You are now 1 dvd!
:P -
After I asked the same question, with help from the great people here I found this site:
REQUIRES VIRTUAL PC
http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl
It worked perfectly with Seven and Stargate. Fast and easy with freeware
Hope you dont mind the EDIT.
We are in a Mac Forum.
This works wonders. This is exactly how I did it for the 2 dvd to 1 dvd's i have done.
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
Double Sided DVD to DVD-R
By craigwojo in forum DVD RippingReplies: 4Last Post: 22nd May 2007, 09:16 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
