Shoot me down if you have to but there are so many results on the subject i still dont know were to start
Ive downloaded this media file and want to convert it to DVD format but when i use Tmpgenc to do the job the audio goes out of sync
i saved the audio as a separate wav and the video as a direct steam copy using virtuldub then reencoded with Tmpgenc to ntsc dvd format but audio out of sync
the wave file shows up as being 3 seconds shorter(02:09:56) when played on media player
i have also scaned for bad frames with virtdub but it came up clean
please help to fix this problem (step by step would be nice)
file properties
WIDTH ; 352 PIXELS
HEIGHT ; 272 PIXELS
AUDIO
DURATION ; 02:09:59
BITRATE;48kbps
AUDIO FORMAT ; MPEG LAYER-3
VIDEO
FRAMERATE ; 29 FRAMES/SECOND
DATA RATE ; 102kbps
VIDEO SAMPLE SIZE ; 24 bit
VIDEO COMPRESSION ; DivX CODEC
avi2wav results
FILE SIZE; 815,980,100
RESOLUTION; 352 X 272
TOTAL FRAMES; 233,763
CONTAINS AUDIO CHUNKS; YES
AUDIO FORMAT; MPEG LAYER 3
SOUND; STEREO
SAMPLE RATE; 24000 Hz
Results 1 to 1 of 1
Newbie debugging sync audio video problem
By siocnarf in forum Video ConversionReplies: 3Last Post: 24th Apr 2012, 21:42 -
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 16:35 -
Newbie trying to convert using WinFF - audio sync problems
By bogey44 in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 09:08 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38
