I have just converted a film via TMPGEnc to re-encode and ulead dvd factory to author.
The format is NTSC and the film is approx 2hrs 11 mins long.
When I re-encoded and burnt to dvd all the film is there (I can confirm this as I watched it) but all my dvd players inc my pioneer 105 via power dvd show it as only approx 105 mins long???
Where have I gone wrong or is this a usual fault!
BTW I have done the same process a number of time for a PAL film with no problems???
I am no expert but I think that the MPG file store the header information at the start of the file. Perhaps it has stored the wrong infomation, e.g. the source type might be store as PAL but the FPS information in the NTSC equivalent (29.96 fps).
Does the following information make any sense:
Actual Film Length = 2 hr. 11 mins, i.e. 7860 seconds
a) Total frames stored in the header as per PAL secification = 7860 * 25 = 196500 frames
b) Film length calculated by the player (as per NTSC frame rate) = 196500/29.96 = 6558.745 seconds = 109 minutes
I am totally guessing by the way.
But then, if you are confirming that the full film exists and you are able to watch it properly, then why bother? 8)*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 15:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 09:29 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21
