Ok, So I was at the store the other day and I stumbled upon these 4 dvd players that I am considering purchasing one, yet I don't know which... Are these any good? I need VCD, DVDR, mp3 playback and good video quality and would like it to be PROGRESSIVE SCAN.
1.) SONY DVPNS325/B $89.99
2.) Samsung DVDP230 $78.88
3.) Panasonic DVD-S35UP-5 $99.99
4.) Toshiba SD-3900 $99.99
Results 1 to 9 of 9
I personally own 3 of the Panasonic S35's. They have played everything I throw at them. I needed compatibility with SVCD's with menus, which the Sony couldn't handle. However, I have read where others have had some compatibility issues. If you can find a store that has them hooked up, do what I did....Take your written media down and try it on the various players. I took home the S35 and went back for 2 more. You should be able to purchase one now for less than the 99.99.
Burn Baby Burn
It's a Disk-o Inferno -
I'm a proud owner of the Panasonic S35 also.
The MP3 support is really nice. The folder view and navigation was well thought out, has a nifty find feature. The unit will also display CD Text.
It does play NTSC VCD, DVD-R (Princo 1x, Ritek G03, Samsung 4x, Optodisc 4x, Prime 4x, Prime 1x, TDK), MP3 VBR tested upto 320. No ID3 tag support. Couldn't get it to play MP3 on DVD-R. Plays DVD-RAM (VR mode only, not data nor ISO).
The Panasonic is also progressive scan.
There is no quality difference between this unit and any of my Apex players on a 27" and smaller TV. On a 32" widescreen, and with a projector, the Panasonic is miles ahead in quality. -
do DVD-R's play good then and VCD's, because that's what I'll mainly be playing.
My Hitachi would lose sync with my original dvds and vcds, I want to make sure that this laser is strong in this panasonic and will play dvds/dvd-rs/vcds just fine. -
Yes, the Panasonic will play all of the above superbly.
Burn Baby Burn
I have the Panasonic-DVD-S35 as well. Great unit plays it all. Also have the Sony, no problems but Know it won't play SVCD.
Awwww I was all set to buy it then I read the hacks section and find out there is no Region FREE code, nor Macrovision!?!
BAH what good is it then.?? Now I am back at square one.
Capture choices
By EagleAye in forum Capturing and VCRReplies: 15Last Post: 27th Nov 2010, 12:25 -
2 choices, you decide
By MackemX in forum Off topicReplies: 1884Last Post: 27th Mar 2010, 02:55 -
Video to TV Choices
By classic2step in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2007, 17:23 -
how configure nero 7 to start up on DVD choices
By zmartha in forum Software PlayingReplies: 4Last Post: 13th Aug 2007, 19:54 -
Need serious help with MUSIC choices
By jimcornetet in forum EditingReplies: 0Last Post: 15th Jun 2007, 14:23
