Considering the Sony DRX510UL EXTERNAL DVD burner. Any difference in operational capability of an external DVD burner and an internal DVD burner. I'll be using either firewire or USB 2.0.
No problem (apart from probably requiring another socket to plug the PSU into).
Internal or external, to coin a phrase it should do exactly what it says on the tin. -
f you're using extrnal version, use firewire rather than usb2 for burning to dvd-r. dvd+r will burn fine under usb2 but many people seem to have problems burning to dvd-r.
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 11:32 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 17:33 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 11:45 -
Internal V External HDD for video editing work
By Rudyard in forum ComputerReplies: 11Last Post: 18th Apr 2008, 03:21 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 17:12
