  1. Tried converting a divx to dvd format.Used tempgen and got 2 files.Dragged both files into the asset windows and compiled the dvd.The picture is great but i have no audio? Any ideas what went wrong?
    I also tried it with force audio in movie
  2. Member mastersmurfie's Avatar
    May 2003
    What are the specs of the audio file? With TMPG you "should" have gotten a video and an audio file...Hopefully an MPG of some sort and probably an AC3 or PCM audio file...
  3. i got a m2v file which was around 3.5 gigs and mpeg file which is 234 megs in size.The mepg plays the audio and it's the full length of the movie.
  4. Member mastersmurfie's Avatar
    May 2003
    you might try the guide posted here:
    https://www.videohelp.com/tmpgencdvd.htm
    or, try changing the filename to *.mpa--this "might" work
  5. i i'm using that guide...Just odd..I even tried making a dvd mpeg with video and audio in the same file.Picture is perfect but no sound
