Results 1 to 20 of 20
  1. Ok, I have a html document (my website) and need info on how to serve it so you fine people can see it.
    Basically how do i set up a webserver? I dont want to use any of the free services like angelfire or something with ads.
    I have a 1.2Mbit DSL connections so it should be fast enoguh.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    if you mean on your own system:
    if you dont have a static IP , get hooked up with a dynamic domain name server http://www.dyndns.org/
    (free)
    next - install a HTTP server other than the microsoft one ..
    http://httpd.apache.org/ (the standard)
    http://www.aprelium.com/ (real easy to use and set up and secure)
    both of the above are free for non comercial use.
    get a firewall and set it up to allow only port 80 incomming and for the web server exe you are using (zone alarm , tiny , etc)
    set it up
    OR
    get hooked up with one of the many free web servers on the net that dont have ads --- there are many that are free or almost free ...
    lists on google - here is one to get you started ...
    http://www.freewebspace.net/
  3. I would recommend hosting it online using either a paid server or a free server.
    In my experience hosting webpages from your computer is asking for trouble unless you really know how to set it up properly.
  4. Member Treebeard's Avatar
    Aug 2002
    All about hosting your own webpage. http://www.dslwebserver.com/
    Jul 2001
    Maryland
    Becareful because many many many isp's have a "No server" clause in their TOS.
    They don't seem to care to much if u just do it a lil(comcast) (i used to serve pictures to my friends so i dind't have to upload them)
  6. I am looking to register my own domain name. Does anyone have any good companies I should check into for the registration? I am looking for a company that will do it not too expensively, and one that provides mail also. i.e. adamthole@mydomainname.com I will be doing the hosting myself (after about 2 months anyways) so I am not too worried if they host or not. However a cheap host I could use for about 2 months would be nice if anyone knows of any. Thank You.
  7. www.godaddy.com
    $8.95 for a .com address, less if you register it for more than 1 year or use a different ending like .net, .us, .org
    www.hostingplatinum.com
    Pretty cheap hosting, I believe $6.99 a month
  8. p4host.com is only 3.99 a month...not too bad either.
  9. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    if you don't mind ads or popups, www.freeservers.com will host for free (and I think it's $1.99 a month for ad-free).
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  10. www.doteasy.com offers domain registration for $25 1 year and free web hosting. no adds no popups.
  11. Originally Posted by BJ_M
    (free)
    set it up
    Does anybody have a step by step guide that can tell me how to use these two pieces of software. Also I dont know if i have a static or dynamic IP address, how can i find out.
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    the second one comes with a help file and real easy to install - basicly it walks you through it ..
    for apache
    http://httpd.apache.org/docs/windows.html
    http://www.thesitewizard.com/archive/apache.shtml
    http://www.cfdev.com/apache/installapache.cfm
    don't get me wrong .. apache is quite easy to set up also ..
    i am very certain you have dynamic IP -- though you may have the same one for a long time if you are on cable..
  13. maybe I am missing the obvious, but when i install apache, it asks for Server name, domain name, and administrative email. What do i put for these?
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    server name = the name of your computer (host name) , if you are not sure, in a command window type "ipconfig /all" and see what your host name is ...
    domain name is the name that you signed up for at the dynamic domain name server .
    your adminisrative email is your email address .
  15. Originally Posted by BJ_M
    set it up
    Ok i set up the abyss web server, but it really didnt require me to do anything other than copy my html files over to the htdocs folder and make a username and password, am i missing something?
    Also what do you mean by "secure"ing it? How do i go about doing that. Also, i am new to the firewall thing, what one would be the best, also is there a free one?
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    free firewall http://download.zonelabs.com/bin/free/1001_cnet_zdnet/zaSetup_37_202.exe
    make sure you allow your app to work as html server ((port 80))
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    test your web server by clicking HERE
  18. ok, I had somebody else suggest Xitami, so that is what I am using for now. I finally got it up and running, got Zone Alarm set up adn every thing. Now I want to do everything in my power to secure this computer. I dont want any hackers or anything like that. One more thing, a friend who is computer savvy said that it would be very easy for somebody to get my password's if i was using web based administration and ftp, thus giving anybody access to my entire harddrive, is this true? I need to lock this down and keep this from happening? Is there a way where it could encrypt the web based and ftp passwords?
  19. Член BJ_M's Avatar
    Jul 2002
    Canada
    if you want NO possibility of someone hacking your system --- don't run a web server on your main box.
    -to reduce it the possibility anyway:
    run linux instead (can sill be hacked though, sometimes even easier if its not set up correct) ..
    dont run windows logged in as adminstrator (root)
    do a search on google , how to secure your web server .... lots about this ..
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    btw, Xitami is a nice little web server also --- i used t use it .. i didnt think it was around anymore is why i didnt suggest it before.
    its ftp service though , make sure its off ... its a bear to configure and just not that good .. the http server is fine though .
