hey everyone,
i am in a little bit of a problem you see. i went on this game site and i viewed a trailer of a game and i liked it so much that i wanted to save it as MPEG and burn it to VCD using NERO. there is only one problem, the trailer was viewed by quicktime and i dont know how to convert it to MPEG. can anybody tell me how to go about doing this? thanks.
Results 1 to 19 of 19
use tmpgenc
goto guide section select the conversion MOV to VCDEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
the file i gave you is a vcd ready-to burn mpg. he just needs help burning iy with nero. i use a mac, so i don't know how to burn vcds with nero.
hey ejoc can u go throught the steps after i download it (TMPGEnc) and then run it, what do i do now.
unstuff? what does that mean? do you mean decode or convert. please help me if you know how to work with PC.
I think he means it was a *.HQX file, the abbreviation for BinHex.
BinHex is a coding of 8bit words as 7bit words, so that they'll not get corrupted over the internet. BinHex files are seen on Macs and the original is usually a STUFFIT file (the Mac equivalent to *.ZIP).
If you have an HQX file (whether on PC or Mac), download a copy of Alladin Systems Stuffit Expander which gives you free capability to decode BinHex files and to expand Stuffit archives, leaving you with the original files/folders.
Of course, I could be wrong.
Scott -
hey cornucopia
is the stuffit expander freeware?
also which one do i download, can u tell me
the steps to take after i download it, thanks. -
yes...it's free. your computer probably even came with it.
anyway, here is the most up to date version:
http://tempest.aladdinsys.com/aladdin/downloads/win/STUFFITS.EXE -
square or cornucopia can any of you get the stuffit thingy and expand the file then upload it to me please pretty please. the URL for the file is:
http://www.easportsbig.com/games/nbastreet2/downloads.jsp
then click the last link
upload it to me by PM @ skip2mylou
thanks for any one who can help me out
i really appreciate it -
did you dl expander? just open the file that i uploaded for you with that and there you go...a ready to burn mpg.
square wat do u mean by dl expander i stil have the file you gave me so wat do u want me to do?
wait a sec how do i expand first i installed the stuffit thing then where do i go from there?
did you figure it out? it is just a compessed file (like a zipped file). you just need to expand it using stuffit expander. i don't know exactly how it works on a pc (i use a mac). it should work like winzip.
Stuffit files work exactly liek zip files. When you unzip a file it is the exact same as you unstuffing a file. They are just different forms of commpression, that's it. From what I've read square has given you a stuffed .mpg file. So all you have to do is use your newly installed Stuffit program to "unzip/unstuff" the file he game you. There sould be a mpeg file inside. You'll then burn that mpeg as a VCD using Nero, or any other burner software you use. And that should do it.
Quicktime to flv convert with ffmpeg
By ades567 in forum Video ConversionReplies: 2Last Post: 27th Jul 2009, 09:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 19:49 -
Best program to convert Youtube to Quicktime
By Soccerman77 in forum Video ConversionReplies: 2Last Post: 24th Oct 2007, 03:53 -
trying to convert from quicktime to FLV using ffmpegX
By gokes in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2007, 11:03 -
convert divx to quicktime
By Shaorin in forum Newbie / General discussionsReplies: 8Last Post: 23rd May 2007, 08:03
