    Jul 2003
    Florida
    3 Questions:
    Which one is faster?
    Which one is easier?
    Which one is overall the best?
    Looking to buy one of them and I want the best one.
    "Wanting people to listen, you can't just tap them on the shoulder anymore.
    You have to hit them with a sledgehammer,
    and then you'll notice you've got their strict attention."
    -John Doe in Se7en
  2. Come on now, you can't decide what flavor you like?
    Try them out (trial versions)
    Based on your other posted question.......................
    Speed- DVDshrink, DVD2one, IC7
    Easier- DVD2one, IC7, DVDshrink
    Quality on Large compression- IC7, DVD2one, DVDshrink opposite of speed :P also IC does not always get the size right.
    Overall- ????? No clear winner they are all good.
    Best value- DVDshrink is Free
    I use IC 90% but that is me. Most other people not. I have great respect for the these programs including DVDshrink.
