Ok, everytime i get an XVID encoded file, it makes my TMPGEnc crash somewhere in the file, i've tried reencoding with virtual dub and it is no help. Can someone give me some tips on how i can go about re encoding it so i can convert to vcd/svcd with no problems.
try completely uncompressing the audio. i think you can do that in virtualdub also
and, in tmpegenc, change the priority for directshow in the vfapi plugins. make it higher or highest. see if that will fix it.poop. -
use this prog and then use the avi file it creates to encode
http://homepage.ntlworld.com/matthew.neaves1/decompress.zip
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 02:48 -
DivX/Xvid conversion
By joecass in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 15:23 -
Xvid to DVD conversion
By Meriks in forum Authoring (DVD)Replies: 5Last Post: 5th Apr 2008, 10:43 -
Help with conversion to Xvid
By zovx in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 15:32 -
720p to XVID conversion?
By deadseasquirrel in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 20:38
