just bought 5 discs of THAT'S WRITE DVD-R's 2X looked it up on dvdinfo and it shows up as TDK G02, anyway i was just wonderfing if this is a good thing or bad thing, i havnt had any probelms yet with the 2 discs i had burned. heres the media code.
0 42 00 00 01 40 C1 FD 9E D8 50 00 02 88 0C 11 .B...@....P.....
76 67 80 00 03 54 44 4B 47 30 32 00 04 30 30 30 vg...TDKG02..000
30 30 30 00 05 88 80 00 00 00 01 00 00 00 00 00 000.............
Results 1 to 10 of 10
If it's a genuine TDK, they should be pretty good... however, if it's the hijacked version AKA Princo, you might be a little disappointed.
maybe they are hijacked cause they dont say TDK anywhere on the DVD.
this really sucks cause i was all exited
is there anyway to check if it hijacked for sure? -
I suppose you could always drop That's Write / TDK a line.
I'm sure if you send an e-mail to That's Write and CC it to TDK, you would get something good out of it - like a freebie box of media from TDK if it's a hijacked code and you put them on to it ! -
well heres my email to TDK with there response. Looks like they are fake
Dear Valued TDK Consumer:
hello I just bought a 50 pack of That's Write DVD-r Media and they said it
was authentic TDK media when I look it up in DVDinfo a program i have it
has
this code
0 42 00 00 01 40 C1 FD 9E D8 50 00 02 88 0C 11 .B...@....P..... 76 67 80
30 30 30 00 05 88 80 00 00 00 01 00 00 00 00 00 000............. Is this
authentic TDK or is it fake thanks if you can verify this.
Reply:
We do not sell discs to other companies at this time, so this appears not
be a geniune TDK disc. It is most likely counterfeit, as no other company
should be using TDK's idenitifer code.
Thank You
Media Support Department
TDK Electronics Corporation.
I also emailed That's Write no response from then yet. -
I was under the impression that TDK weren't in the OEM business but wasn't sure - I didn't want to say that in case it clouded the issue.
If you bought the discs on the grounds of the TDK code then send your supplier a copy of the mail and get your money back. A reputable company will not want to associate itself with what is effectively pirated goods. -
Just saw this on the "Blankdiscshop.co.uk" website ....
{DV 328} BULKPAQ GREEN (2x) 4.7GB DVD-R discs in a Spindle tub of 50
The 2x version of the popular Bulkpaq budget priced disc.
These discs are now being packed by the manufacturers into 50 disc spindle tubs to ensure they reach you in first class condition.
Suggested for use on the following hardware:
Pioneer 103/A03 , 104/A04 , A05/105,106/A06 and
Sony DRU500a .
These discs are capable of writing at 2x in 2x/4x capable writers.
ADVDINFO: TDKG02..000
Equates to 69p per disc! £34.49 Including VAT at 17.5%
Does this mean that these are also illegal copies? Or are they TDK discs printed with the Bulkpaq logo? -
it appears that they are illegal copies, according to the response TDK gave me
@energy 80's...they CAN'T be authentic or even OEM TDK disks because if you look at Q9's response post from TDK....he copied TDK's reply. It says right there that TDK at this time does NOT sell disks to other companies. Just another case of "identity theft" so to speak....Does this mean that these are also illegal copies? Or are they TDK discs printed with the Bulkpaq logo?
Apparently, the only legal discs with the TDK manufacturer's ID code are discs such as the TDK DVD-R47EA. These are Made in Japan at TDK's own manufacturing plant.
TerminalVeloCD
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 19:42 -
what is wrong with these TDK?
By twister6 in forum MediaReplies: 21Last Post: 26th Feb 2009, 13:50 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 16:21 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 08:55 -
What should I do with these TDK's
By Waltj in forum MediaReplies: 6Last Post: 2nd Jun 2007, 23:27
