Hi there,
when capturing with FastCapture in combination with Power Play (under Win98SE) in 768*576 PAL the result is very good. even fast horizontal movements are perfect (no choppy moves with vertical lines such as lanterns and so on). as long as i put the result out to VCR the picturequality keeps fine. PowerPlay does a good job! But when converting the AVI to MPEG (it does not matter if VCD or SVCD-Formats) im getting back this choppy movements when having fast horizontal moves. the same happens when i take virtualdub as the capturing programm, and it does not matter what resolution or codec i try (i.e. Pegasus mjpeg registered quality 20, res tried 768*576 and 352*28. Filters in vdub cannot solve this problem
does anyone have this problem too or cah sb tell me a good capturecard that works with win2000prof fine???
Guest
hi
i don't know if my reply is of any help but since you have not got any yet:
i use avmaster myself for capturing hi8 videotapes
system: win98 PIII 550 256 mbram
i use tmpenc to convert to mpeg2 and it works fantastic.
of course it takes a lot of time: 12 hours for 40 minutes of playing time, but cristal clear!!
perhaps your problem is with win2000 since i read on forums about problems with win2000 (fast did not make a good update for it) look at the forum of fast.
good luck
Problems Capturing from Vidoenics MX-1
By John Duvall in forum Capturing and VCRReplies: 0Last Post: 15th Dec 2010, 08:04 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 14:09 -
Capturing footage-problems ...
By perik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 7th Dec 2008, 18:11 -
Having problems capturing my 360 on my PC
By RR420 in forum Capturing and VCRReplies: 4Last Post: 23rd Feb 2008, 11:50 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 03:41
