Basically, I have bought some CD-R 90 (800MB) discs.
I want to use the full capacity so that I can save more to the disc.
For instance, save an extra few minutes of SVCD.
I usually use VCDEasy to save to the CD.
However, all programs I have treat the CD as if it were a max of 700MB.
Any ideas?
Cheers
First and most important, make sure your cd-burner is compatable w/ 90 min discs.
It'll still be recognized as an 80-minute/700MB disc. You have to enable overburn, and just put 800MB data / 900MB video on it and it should work.
I think you mean 800mb data and 90 minutes video.Originally Posted by sterno
Are they inifiniti disks?
90 min infiniti disks will not give you 90 mins on all hardware, it all depends on your hardware.
For instance, a lite-on drive might give you 89.5 minutes whereas a Pioneer may only give you 86 mins.
I used Nero and successfully achieved 89-ish mins (using overburn).
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
No, I really did mean about 900MB video, which will be 90 minutes of standard VCD or CD audio. For XVCD or SVCD you can have more or less running time, but the limit is still going to be around 900MB (probably a little less because of the overhead in making the disc) for your source file. Since I rarely make standard VCDs or audio CDs I always think in terms of the file size(s).Originally Posted by Will Hay
Okay, I didn't know thatOriginally Posted by sterno
It's been a while since I made anything other than dvd but I thought vcd was measured in minutes with regards capacity.
Thanks for putting me straight
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 13:38 -
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 09:26 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 18:47 -
.FLV for 10 minute video way too big
By Pureweb in forum Video Streaming DownloadingReplies: 48Last Post: 28th Mar 2009, 04:53 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 17:50
