Hi,
I wish to backup some DivX movies. However, rather than convert them into VCD or SVCD, I burn them into blank cdr as they are (DivX format), using Nero as DATA.
The problem is when I try to play the movie from the cdrusing my pc, it says format not recognised. However, when I copy the file from cdr to my hard drive, then play it back from hard drive, it works. Not sure why??
I am wondering if there is any burning software, which is used to copy DivX into blank cdr?
Regards,
danny
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I gues you mean that there is no autostart when putting a divx-disc into rom, right? You need "divx launcher". It's a small tool that does what you want.
Keep on capping it,
I'll keep on downloading it.
Watching movies on HTC HD2
By me-eyes in forum Portable VideoReplies: 2Last Post: 2nd May 2010, 16:02 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Question on watching movies in high-def.
By dimtim in forum Newbie / General discussionsReplies: 9Last Post: 28th Sep 2008, 09:22 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
new monitor for watching movies on my PC
By hilario in forum ComputerReplies: 3Last Post: 10th Aug 2007, 19:21
