I have aproblem when using tmpgenc. Everytime i start the encoding, i will get a write error: "write error occured at address 77F8336F of module 'ntdll.dll' wtih 00000000"
I'm not sure what I am doing wrong to get this error. My source is a divx avi and the extracted wav audio
Typically that's a corrupted install of TMPG. To fix it try this:
1) Reboot
2) Un-Install TMPG, delete folder
3) Reboot
4) Install TMPG
5) Encode and Enjoy
This has nearly always fixed any TMPG issues for me.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
also, if you're running windows XP, download the service pack. the official release of XP had some problem with ntdll, they fixed that, but when you get the service pack, dont get all of the internet explorer security updates, one of them is corrupt and will lag your computer. MS supposedly fixed it, but last i heard, it was still doing it.
poop. -
the stupid service pavk won't work in my pc some crap about my serial
or kernell.
after you download it, there's a way to do it manually instead of running the .exe. search google.com for help on that. i did it once.
poop.
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 19:58 -
VirtualDubMod ntdll error.
By tat2jr1 in forum Video ConversionReplies: 10Last Post: 25th Jul 2009, 08:15 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
Access violation in module ntdll.dll
By Blå_Mocka in forum AudioReplies: 3Last Post: 10th Feb 2008, 14:09 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 19:28
