The original DVD movie is badly scratch to a point when I watched it, the picture would skip/break/crack. When I encrypt this DVD using DVD Decrypter, will the skip/break/crack from the original DVD transfer to the encrypted files?
Thank you very much.
Actually, it's more likely you won't be able to decrypt the movie at all, depending on how bad the data is.
If the data *can* be read successfully you won't get errors on the subsequent DVD -- there are also some measures (some more drastic than others) you can take to try and repair this to get a good read: anything from gently washing the disk to using one of the disk polishers on the market or even Pledge (I think) to try and fill in the cracks. Good luck."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Yes. A DVD can only correct up to approximately 2800 bytes. Your scratches exceed that. Your only hope is that your DVD-ROM is not affected by these scratches (RE: focuses beyond the defects).
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
well when i rip a cd that is scrached it will play just like the original so hopefully this is different with dvds cuz if it has scratches it will copy the same exact scratches to the copy your making
SmartRipper has a reputation for being more forgiving of scratched discs, than DVDDecrypter.
How to make a Karaoke DVD from scratch?
By MadeInBrazil in forum Authoring (DVD)Replies: 3Last Post: 15th Dec 2010, 12:06 -
Movie DVD with bad scratch
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 26th Jul 2010, 13:25 -
Need help related to further encrypting and decrypting media file
By binnyshah in forum ProgrammingReplies: 0Last Post: 25th Jun 2010, 04:12 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
Is there any way to force rip a scratch dvd?
By tendra in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2009, 19:46
