Hi everybody, can someone please tell me what re and demuxing means. also i have another problem, i used my dig. camcorder to capture on MiniDV tape but my capture is 1 hour and the tapes are only 30 mins so i had to use 2 tapes. is there anyway that i can connect the two video files on my computer so that i can burn them onto VCD using NERO?
Originally Posted by skip2mylou
https://www.videohelp.com/glossary#Multiplex
https://www.videohelp.com/glossary#Demultiplex -
1) mux is short for multiplex: https://www.videohelp.com/glossary#Multiplex
Demux: https://www.videohelp.com/glossary#Demultiplex
remux is the same as mutilplex
2) You can use nero to put two vcd standard mpg's on one CD, just use the "creat VCD" option and drop and drag both mpg's into the play list. -
Yep.Originally Posted by FT Shark
Usually I tune out after I see the letters "DV." I know nothing about DV. Shark made a good recommendation, and I'll add you can even add a menu with Nero. Works great for a couple episode of cartoons one one CD.
i know but there will be a pause in the middle and i want it to be a continuous video, how do i do this so that the two files i have can be joined into 1?
You can use virtualdub to join files. I'm not at my computer though so I can't tell you how off the top of my head.Originally Posted by skip2mylou
You need to either right click or double click on the file that you droped into the playlist and options will appear. The delay time between mpg's is one of them. Just set it to zero.
Audio/video out of sync after demux-remux
By CarryNL in forum SubtitleReplies: 0Last Post: 14th Sep 2011, 14:31 -
Capture out of sync after demux/remux (framedropping)
By Bingo-days in forum Capturing and VCRReplies: 3Last Post: 13th Jan 2010, 08:41 -
demux m2ts streams and remux them together with srt subtitles
By TwilightMatt in forum Video ConversionReplies: 5Last Post: 9th Dec 2009, 11:10 -
Demux mkv -> remux Divx
By nsx3000 in forum Video ConversionReplies: 4Last Post: 15th Sep 2009, 09:12 -
can not remux after demux
By volam in forum EditingReplies: 2Last Post: 19th Mar 2009, 15:36
