Hello,
I have a bunch of AVI's (Simpsons Episodes).
I'd like to convert them to a DVD-R. There are 22 Episodes with an average time of 23:10 / AVI.
How should I go about converting them to a DVD? Ideally, I'd like a menu listing all episodes, and then separate chapter points in each episode.
Thanks,
Cam
FIRST thing you need to do is convert your AVIs to DVD complian MPEGs
Check the CONVERT and GUIDES sections at the left for more info
You will NOT be able to fit all episodes onto one disc...will need to span probably several discs... -
Actually, if your DVD player works with it (and very many do) You can make all your stuff fit on one DVD using the Half D1 KDVD template from kvcd.net. Since Simpons are animated, there won't be a lot of colors, so it won't be that hard to fit all 8 and 1/2 hours on a DVD with quality at or almost unnoticablely near to your source. Your audio bitrate needs to be 160kbps or lower.
You need to frameserve from VDub to TMPGEnc with the framesize resize filter in VDub set to whatever is standard for your video system (NTSC or PAL). You'll learn these standard frame sizes when you go to the KVCD website.
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Converting multiple AVI/mpeg files and 'chapterising' them
By warren218 in forum Video ConversionReplies: 7Last Post: 18th Feb 2009, 10:24 -
converting multiple avi files to mgeg at once
By killagoob in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2008, 05:02 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 14:23
