Hi - I want to convert a video from xvid of resolution 576*320 to xvcd mpg. I can do this but just wanted to ask is it better to increase the resolution to 720*480 or to decrease to 352*240 (using 1900kbps video bitrate)? I'll be playing this back on a 40" Loewe CRT TV.
Priesh
With a bitrate of 1900 I would test 352x480(cvd and dvd standard so it should work pretty good).
Why you wanna convert?
I've used weird xvid res to svcd without problems...I just convert with TMPGenc and ignore the warnings on VCDEasy when I go to image...no problems so far... -
do MPEG 2 like this
then use GOLD WAV to convert the audio to WAVE.
now just drag the avi file in here and it takes a while to decompress audio. now when its done put file save as wav.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
do you use reselutions, like 480*480, or reselutions like 520*246 and s**t like that. cause if you use weird reselutions, it might work on your player, but not on many. plus if you want to put the movie on a dvd-r/+r you will have to convert the whole movie as those reselutions are not standard to the dvd specs.Originally Posted by BookmdAn all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
Thanks for the replies but i dont want to convert to svcd as my dvd player cant play svcd (header trick doesnt work properly either) - just normal vcd with higher bitrate hence XVCD.
Priesh
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
