I am looking to get a capture card so I can capture things from VHS to burn to VCD or DVD.
What I want is a card that can capture straight to DVD or VCD ready MPEG from VHS. I see a lot of cards that say they have realtime MPEG encoders that can do this. Does this also mean that if I have some AVI files it would be able to encode them to MPEG faster?
So what capture card should I get?
Results 1 to 9 of 9
I've tried to help friends and family with their cheap-o cards, and all I've got to say is that I'm glad I have my ATI. I'd never want to deal with their problems on a daily basis. Outside of an ATI card, I've never seen another card do good on MPEG capture. It's top quality, it's compliant DVD quality, and it works. A bit of tweaking in the software, but I wrote a guide (and will be expanding it soon) to help out with that.
nope - the two are not related - one is capturing from an external source, the other is an internal conversion.Does this also mean that if I have some AVI files it would be able to encode them to MPEG faster?
as for which card - figure out what you are willing to spend. check the Capture Cards section at left and look for cards in your price range, and see what other users had to say about them.
for me, I didn't want to spend more than $50 when I got my card, so I looked around and found the Aver EZDVDmaker - decent reviews, inexpensive, not hard to set up, and it was in my price range. And I've been happy with it - it's given me a good bang for the buck.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
LORDSMURF,
Will any ATI AIW do or should he look at a specific one?
Which one do you have?
SLICK RICK
Originally Posted by lordsmurf -
I have an AGP ATI All In Wonder Radeon DDR32 (which is the 7200 chipset), and the PCI ATI All In Wonder Radeon 7200. I tried the TV Wonder and the VE-something, and I took those back to the store. If I had it to do all over again, I'd have gotten the AGP instead of the PCI for my second card, but I've got it working (see past posts for my problem, which ended up being RAM, onboard soundcard, and PCI speeds).Originally Posted by SLICK RICK
I'd say shoot for either the ATI AIW 7500, 9700, or 9800, depending on what you can afford.
I've seen the VIVO and the older 128 PRO in action (friends that have them), and it wasn't impressive. It appears that only the AIW RADEON cards are the good ones. They've since added 9000 cards to replace theirs.Want my help? Ask here! (not via PM!)
housepig,
Is this the one you have?
http://www.newegg.com/app/ViewProduct.asp?DEPA=1&submit=manufactory&catalog=47&manufac...n=&Order=price
SLICK RICK
EDIT. I am referring to the first one on the page.Originally Posted by lordsmurf -
Slick Rick -
yep, that's the one.- housepig
Housepig Records
out now:
housepig,
Does it give good quality captures from vhs?
How do you capture the sound?
SLICK RICK
I think soDoes it give good quality captures from vhs?
I get better quality if I capture to avi and convert, rather than capturing direct to mpeg.
I run the sound into the onboard soundcard.- housepig
Housepig Records
out now:
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
