hi
i'm going crazy with this. everytime i try to encode one video with cce i get some weird macroblocks on the mpv file. the source is fine but then the encoded file is shit. anyone can PLEASE try to help me?
i did 2 screen shots of the samples and also a screen shot of my cce settings.
the settings you will see is one pass VBR but i also tried all other mpeg formats.
please help me.
thanks
the link with the screen shots is here:
http://pwp.netcabo.pt/0248749101/cce/
I am no CCE expert but you need to do 3 things right away. You gotta do better than one pass vbr. Do at least 3 passes. Or better yet do CBR. Also you dont need to do max bitrate at 9800. Try 9000 to leave some room for the audio. If you do do vbr put your minimum bitrate at something higher than 0. Ive seen where it is suggested 300. Also for dv material turn off zigzag and put on alternate scanning.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
MEGUI & X264 = Macroblocks
By Cunhambebe in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 11:00 -
DV to H264 at 3100kb/s and still has macroblocks?
By SatStorm in forum Video ConversionReplies: 12Last Post: 25th Jan 2008, 05:39 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 12:14
