I'm a newbie so apologies if this sounds a bit basic.
I've been happily converting SVCD's to DVD's but in reading a lot of the posts here in the Audio section, I'm beginning to think I may be doing something wrong and am losing out on Audio quality.
Following the 'convert' guides, I've decided to stick with the DVD2AVI & TMPGenc technique and although it requires a re-encode of the video (as opposed to the IFOedit trick), I always get a working DVD mpeg at the end of it.
However, if I'm extracting the SVCD audio (using DVD2AVI), then feeding that into TMPGenc (which converts it into .mp2) and then authoring the finished mpeg elemental streams using DVDit PE (which converts the .mp2 into stereo AC3), arn't I losing audio quality somewhere?
Also, how can I extract and then author 5.1 AC3 ??
Yes, you lose quality.
Best bet is to extract the MPEG2 files with ISOBuster and then dump them into TMPGenc. Then only re-encode the video. I'd suggest 352x480 at 3500k for the new size. Then let DVDit! re-encode the MP2 to AC3.
If your source is stereo, you won't get 5.1, and there is not real way to do it. I tried once with BeSweet (still a fake 5.1), but that program always makes my audio skip or crackle after conversion.Want my help? Ask here! (not via PM!)
If your converting SVCD into DVD then the sound is mp2(mpeg) because that's the standard for SVCD. Converting to ac3 won't give you ac3 audio because the mp2 only has 2-channels. Re-encoeing the video can only lower it's quality.
Originally Posted by wulf109Want my help? Ask here! (not via PM!)
I think you've answered my question - thanks to both !
I guess when I use DVD2AVI to rip the sound from the SVCD (which I was told was a better way to do it as TMPGenc sometimes has sync problems with audio), it just rips it as a .mp2 file with no conversion. TMPGenc is just then transcoding the audio & video streams to create the DVD compliant elemental streams ready for processing in DVDit PE.
However, DVDit PE only supports LDPCM or 2-channel AC3 so I choose the AC3 option and it converts the mpeg audio. I guess its at this point that you could say that it's loosing some quality, as it's having to re-encode the audio ?? Is their an authoring system that does support .mp2 audio ??
Slartybartfarst
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 08:48 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 13:36 -
Every Time I Crop, I Lose Quality!
By terminalh in forum Video ConversionReplies: 8Last Post: 18th Jan 2009, 13:04 -
DVDs to DV to DVD will I lose quality in video?
By Endzone in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2008, 05:08 -
.tivo to DVD, I don't want to lose any quality. Which method is best?
By topho in forum Video ConversionReplies: 10Last Post: 10th Jun 2007, 16:53
