Hi hope someone can help.
I have a problem home networking my laptop from work.
I run XP Home on my PC which is set up for Internet Connection Sharing into which I connect my laptop via a crossover Cat5 cable. Everything works okish, I can access the internet, copy files back and forth etc. from my laptop EXCEPT the following strange situation:
When I am browsing from my laptop some sites do not open, specifically google.co.uk, google.com, yahoo.co.uk and uk.news.yahoo.com.
I've checked everything I know, cleared IE history and cache but no luck, what the hell is the matter??
Thanks in advance
Jukka
I could be wrong about this, but I was under the assumption that a crossover Cat5 was only able to connect two comptuers locally - not supply data from an internet source such as a cable modem or router (for which you would use standard cat5 cable and go from source to computer directly)Originally Posted by Jukka
Almost right.
The xover cable is directly connecting my pc to the laptop, i addition I have a DSL connection that runs off the USB port (almost all do over here in the UK), this is shared using XP ICS which affectively then allows other 'networked' PCs to access the web - sometimes!! -
ahhh
gotcha.
why not just run it all through a router, or a wireless one at that sine you have the laptop?
Networking?
By HotDamn! in forum ComputerReplies: 30Last Post: 1st May 2010, 18:00 -
Networking a DVR
By PhoneMatt in forum ComputerReplies: 5Last Post: 20th Apr 2009, 14:21 -
networking issue
By Xylob the Destroyer in forum ComputerReplies: 7Last Post: 20th Dec 2008, 12:34 -
Networking/Internet problems
By Ai Haibara in forum ComputerReplies: 7Last Post: 22nd Nov 2008, 15:19 -
Problems copying a home-made DVD
By jj1807 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2007, 14:20
