I just burned a Data CD using WinXP and it worked great and everything was just dandy. Then I wanted to put the files on my dads laptop, which is using Win98, and it didnt even recognize the disk. Then i tried it on my dad's desktop computer, also running Win98, and it did the same thing. I burned about four disks, using two different programs and none of them worked. So I was thinking that it might be because im using WinXP and then trying it on Win98, but i mean its just jpg files so i dunno. Or maybe its my burner but i dont think so because it burns everything else just fine. O yeah im using a Sony DRU-510A.
i read somthing about this on the winxp update page
there is an update which allows you to make files recognisable on older operating systems like win98 and win me
also check out tweakxp.com for future help on winxp and extra tricks -
I think you are not going to read NTFS files on a FAT32 computer. Vice versa, yes. 98 can't read NTFS
Well the drive that my OS is on is FAT32 and my other HDD that i use for editing and stuff is NTFS.
Burning Data at 4x
By rickoshay in forum ComputerReplies: 9Last Post: 19th Feb 2010, 14:05 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Data Burning Query
By gilera in forum Newbie / General discussionsReplies: 17Last Post: 4th Feb 2009, 04:32 -
Burning data-dvd
By btkuehn in forum Authoring (DVD)Replies: 37Last Post: 9th Oct 2008, 19:55 -
Problems burning avi/xvid as data files
By deuceswild13 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jul 2008, 01:49
