1. I tried SVCD2DVDMPG+ with both SVCDs and VCDs. The DVDs I created from SVCD-Source are all fine, but the DVDs I created from VCD-Source are all out of sync (audio - video). So i am wondering if the sync-problem ist typically for VCDs (MPEG1). Or can it also occur to SVCD-Source (MPEG2) ?
2. I downloaded the menu-samples (badger #1- 3) and extracted them in a subdirectory called "menus". But it does not seem to work. The menu-button is still grayed out. I cannot use this function. What did I do wrong ? And if it would work: Does it still only support 2 movies (VTS-Sections) at the moment (I read abot that), or can I have more than 2 movies in the menu ?
Thanx in advance.
FantasticN
FantasticNGuest
1. Is indeed a vcd problem what you can do to solve it is reencode the vcd with tmpgenc or what i do is only reencoded the audio with tmpgenc and mux the old video with the new audio and run it through svcd2dvdmpg+
2. you only get the menu button if you made 2 vts (and only 2 vts) and put at least 1 file in each vts. -
FantasticNGuest
Thanx a lot for the info. I read about the TMPGEnc-Solution. But I think now that I know that the problem only concerns VCDs I will just stay away from creating DVDs from VCD-Source and just take SVCD-Source.
BTW:
I created a DVD with 3 Movies with SVCD2DVDMPG+. The first 2 were 480x576 25 FPS PAL and the third was 480x480 29,97 FPS NTSC.
I then used WinDVD 5.0 to play them. The first two movies played well on monitor- and tv-screen. But the third was distorted (video was only shown in the upper part of the screen) on my TV, but was shown correctly on my monitor-screen at the same time.
The video of the VCD-DVD was - apart from the sync.problem - totally distorted on my TV-screen (flashing), but also absolutely correct on the monitor screen.
Do you know a reason for that ? When I play the original mpg-files, everything is o.k. on monitor and tv-screen.
Greetings
FantasticN -
you can put more vcd eps on a dvd then svcds but svcds have better quality.
to the second i don't think it is a good idea to put NTSC and PAL on the same disc. -
i think 480x480 is not a proper dvd standard which
can cause problems.most author programs wont
let you use 480x480.unless you patch it. -
Guest
First of all: Many thanx for the answers.
@yf2001usa:
Of course SVCDs do have better quality than VCDs (higher resolution, higher bitrates, mpeg2 instead of mpeg1, etc.). But I have to take what I got. If I my source-file ist an VCD-mpg, then I cannot change it anymore. Re-Encoing to SVCD won´t make sense as it would not mean any increase in quality anymore.
One of the big advantages of SVCD2DVDMPG+ ist supposed to be the ability to put ntsc and pal format on one disc. So refering to the author this should work.
@nednedned
SVCD2DVDMPG+ is a tool for creating DVDs from SVCD/VCD-Source. This is so difficult, because of the fact that all SVCDs and VCDs do not have DVD compliant resolutions. Most DVD-Authoring-Tools (except DVDLab) do not accepts those sources and you have to use a "trick" to get it working. That´s why the tool SVCD2DVDMPG+ exists. It should creat DVDs from SVCDs/VCDs without the need of any "trick".
480x480 is the standard-resolution for NTSC-SVCDs (29,97 FPS). 480x576 ist the standard-resolution for PAL-SVCDs (25 FPS). Both are not DVD-compliant but should be correctly used for DVD-Authoring by SVCD2DVDMPG as this tools is exactly made for those sources.
Bye
Fantastic
DVD & BluRay Menu + Chapter Creation Programs ?
By VideoFanatic in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2011, 23:06 -
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2010, 00:36 -
Questions about DVD creation
By downhilljon in forum Newbie / General discussionsReplies: 22Last Post: 6th May 2010, 16:56 -
Questions about DVD importing and menu creation
By Reading Bug in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2009, 16:24 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 16:24
