hi i was just wondering if there is a way to transfer files from a VCD to a DVD and if i can transfer files from multiple VCDs to 1 DVD. thanks and reply with easy and broken down steps cause i am a newbie.
hey poopyhead can u tel me what to do and break down the steps, thanks.
Read this: it has all the steps.
How to put VCD MPEG1 on a DVD±R/W without reconverting the video.Regards,
Rob -
Or if you want it the easy way go to the forum about SVCD2DVDMPG the program (SVCD2DVDMPG+) will do all the steps for you without problems. I myself have had troubles with this guide to get the vcd on dvd cause Spruce won't load them and Maestro made a mess of the video.
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 02:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
