I have question for you guys. I have an .mpg file that have been segmented into several parts. I would like to re-assemble them into one file - how can this be done? Because it's .mpg, I can't use QT pro to copy and paste the parts and exporting as a .mov loses the audio. What are my options?
Thanks!![]()
Results 1 to 9 of 9
do you have TMPGEnc if so do this, let me post some pics do you at least know if its MPEG 1 or MPEG 2
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
first close the wizard template, and then put file and mpeg tools as shows:
if its an mpeg 1 do this
if its an mpeg 2 do this
now all you do is thisAn all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
hmm i see, well i cant help you cause i dont use mac i would but dont have one. but i love pcs more. lol i have to say that im paid to say that. na j/k i just love PCOriginally Posted by ericdudeusAn all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
use mpgtx. drag all the parts into the window, make sure they are in the proper order and hit "join".
http://versiontracker.com/dyn/moreinfo/macosx/15987
Cecilio...do you realize that this is a MAC forum? stop posting PC answers. -
PLEASE DO NOT POST WINDOWS PROGRAMS OR SOULUTIONS ON A MAC BASED FORUM.Originally Posted by Cecilio
You already have a warning for something, I dont want to give you another one so im telling you now!
Please dont do it again -
ericdudeus
mpgtx will do the job. Just open it, and go to FILE OPEN, and choose your 1st .mpeg. repeat the FILE OPEN until you have them selected (go 2nd, then 3rd, and so on)
the order you open them is the order they will be joined.
Then, clicn JOIN. SPLIT is the default option.
then click START.
You will get a file called CHUNK.mpg which is in the same location as the 1st .mpeg file. -
I tried mpgtx and it seemed to work until I tried played the "chunk" file. The file size said it was 132MB, but it only played 2 frames of video...Maybe I set it up wrong - I dragged and dropped all the pieces, maybe i should try importing one at a time. I'll mess around with it. Thanks for the suggestions!
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 19:08 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
