    Jul 2001
    Maryland
    Shared Borders is greyed out in Front Page 2003.
    How do i get it to let me put them in.
    Dec 2002
    The Great Northwest
    More info???? Have you added the pages in navigation view and can not add a S/B to a list of pages???
    I use a navigation bar in a upper frame on page and bring all others to the main frame, I really like the look. But a shared border should be added in the navigation view if I remember correctly.
    Example:
    Use a quick load page for speed, then a link to the main page.
    http://www.dvd9to5.com
    http://www.dvd9to5.com/start.htm
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
    Jul 2001
    Maryland
    At the moment, I only have the blank index page.
    Dec 2002
    The Great Northwest
    As I understand it you will need more than one page to do this. As you add pages to your site you can add shared borders via the navigation view [no need for S/B with one page]. I do not think you could do this if you only have a index.htm page because you can not share with only one page?? As a test add a few pages save and then try it. It may also be necessary to publish before you use shared borders but you can do that privately on your local harddrive.
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    Jul 2001
    Maryland
    for some reason you have to enable them in the options menu's under sharepoint services.
    seems kinna dumb. anyway, problem resolved
