  1. I'm using TMPGenc and (sometimes CCE) to encode avi's to mpeg. Most are widescreen and I want to convert them to TV size but when I do, the figures are elongated. How do I change this? In TMPGenc or DVDLab?
  2. Dude you'll kick your self!!
    simple check youre input (source) aspect ratio it should be 1:1,
    but if need be change to 16:9.......
    it in the advanced tab when u click setting button in Tmpeg
  3. 16*9 isnt a size it is an aspect ratio..not size
