Ok, I've done this on a mac but haven't tried it using a PC. There are actually 2 ways of doing this.
Method Number 1:
1) Get 4 movies all in the same format. I don't care if they are DivX's, XviD's, 3ivX's or what—just make sure they are all the same format. For example, if 3 of your movies are DivX's and the last one is XviD, convert the XviD to DivX.
2) Once you have all 4 movies in the same format, add them together. That is, make one giant movie file that has all 4 movies in it (make sure you have sufficient HD space as the ending file should be around 2.8 gigs.
3) Convert the large file to a .vob file (for those of you who don't know what that is, it's a DVD movie file).
4) Use a program (for Mac I use DVD Studio Pro) that will create chapters from your .vob file. Each new chapter should be a different movie. Example:
Your first movie is The Matrix. Chapter 1 is The Matrix.
Your second movie is Spiderman. Chapter 2 is Spiderman.
ect.
5) Create a menu with a chapter section.
6) Use a program to create the .bup files and .ifo files (if you have gotten this far, you know what I'm talking about...)
Method 2 (much easier and somewhat faster I think...)
1) Convert your movie's to .vob files.
2) Use a program to create the .bup and .ifo files.
3) Burn.
Results 1 to 1 of 1
Need a tut For AE for removing dead bugs and dirts on a dashboard cam
By Jonz in forum EditingReplies: 0Last Post: 8th Oct 2011, 20:28 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
How to create movies that is playable in home DVD players from a movie DVD
By vain in forum Video ConversionReplies: 2Last Post: 16th Mar 2009, 02:10 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
