i have 2 'Windows Media Audio/Video file' and would like to know how to convert them so that i can burn them to a VCD and play on a dvd player which is vcd compatible.
is it also possible to improve the quality of the picture?
Results 1 to 11 of 11
WMV to VCD
https://www.videohelp.com/tmpgenc.htm
There are some filters that may improve some of the "rough edges" of your WMV but generally speaking you can't improve something if the source is'nt so good."Today is only yesterdays tomorrow" -
hey what burner are u using cause if you download a trial of NERO you can burn without having to convert cause it does it 4 u.
you can download a trial here:
http://www.ahead.de/en/index.html#download -
ppl have been saying nero's encoder doesn't yield very good qualityOriginally Posted by skip2mylou
i think it yields pretty good quality cause i burned a VCD and it played and looked jus like the regular file, but thats jus my opinion, i am a newbie you might want to listen to poopyhead.
Nero is a very poor encoder. Use something like TMPGEnc and you will notice the difference.
Have tried using TMPGEnc but it runs really slow, at the moment to convert a 50mins file it has taken over 4 hours, is there anything else i can use?
try Ulead Moviefactory (free 30 day trial)
and just follow the instructions, it will encode by itself
when you are ready to burn:
http://www.ulead.com/dmf/trial.htm
this is a URL from where you can download the trial
just put in your email and country u live in.
the instructions are:
https://www.videohelp.com/forum/userguides/139093.php -
cheers but really want to use software that will allow you to convert then burn from NTSC to PAL (if you understand that)
yeah sure u can do that too i pretty sure of it.
after you run Ulead Moviefactory, click new
project then VCD or DVD then in the bottom
left corner there is an options button, click it
and go to preferences and you can change it
from PAL to NTSC or vice-versa. try it.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
is there a simple way to convert an avi to vcd?
By lks9042 in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2009, 03:00 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
