Hi I want to know if anyone in this board know how to add subtitles to the movie ...I need instructions. Thanks
Mermaid
there are a number of guides explaining how to do this.
I have been working with anime episodes, so these are a bit more complex.
Assuming you are doing a dvd rip, then use subrip to get the subtitles off the dvd saving them in ssa format, MaestroSBT to convert them to sub format, then WinSubMux to add them into the mpg stream. This has worked well for me, that it has.
If you are doing modifications to the movie, then the subtitle timings need to be adjusted as pieces are added or changed. I havn't found a good tool for this, MaestroSBT has a section for adjusting time, but I can't get it to work correctly. I ended up writting a small c program ot handle all my adjustments.
If you do not have a source for the subtitle, then you can create your own ssa file then add them in, but I never tried it myself.
What is the best way to apply Prolimatech PK-1?
By Stealth3si in forum ComputerReplies: 5Last Post: 6th Apr 2012, 09:37 -
How to apply a black screen on playback?
By therock003 in forum Newbie / General discussionsReplies: 12Last Post: 1st Sep 2011, 03:41 -
how do i apply subtitles to a video in different colors?
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2011, 03:55 -
How to apply filters to video?
By kaona in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 13:59 -
Dont get how to apply filter to a MPEG-2
By noob4ever in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 20:01
