hey whats up?
I was just thinking how awesome it would be if one of these dvd shrink type programs, in future versions would be able to do the following:
Convert Pal to ntsc or vice versa for the whole disc.
it easy enough to convert now if you rip a disc and then use tmpg (or other app) but it's a hassle if you want menus, stills, etc.
Would it not then be great that in addition to a program shrinking the disc to fit on one dvd-r (and lets say using full disc mode for the entire dvd) but converting it over to the desired format along the way. Sure it would take longer but it would be worth it.
What do you think?
Suggestions for MOV to MPEG4 and AVI converter
By ITemplate in forum Video ConversionReplies: 3Last Post: 29th Jun 2011, 14:36 -
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 19th May 2010, 00:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 04:19 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 18:57 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33
