    Feb 2003
    Central Virginia
    Greetings all,
    Does anyone have experience converting and burning an mpeg file extracted from a TiVo?
    I have been successful in the extraction from my TiVo to my Mac, and can play the resulting mpeg file just fine in QuickTime Player.
    However, I am stumped on how to convert the file using ffmpegx to burn as an SVCD.
    Any help and /or pointers would be great.
    Thanks to all!
    Jim
  2. I am thinking of getting a Tivo/ReplayTV how do the mpg files look? Quality wise? Does it save a mpg1 or mpg2 files?
    Sorry to not be able to help with your question, but thanks for the feedback.
    Major, will assist you when he has a moment, he is excellent and cares about his software. Good luck!
    Feb 2003
    Central Virginia
    >I am thinking of getting a Tivo/ReplayTV how do the mpg >files look? Quality wise? Does it save a mpg1 or mpg2 >files?
    As far as I'm concerned, it looks pretty good. It's mpg2 format, with the audio set to 32khz. The bit rates can vary from 5.8Mbps (Best Quality) to 1.47Mbps (Basic Quality). I think that if the mpeg is deinterlaced, it will look better. I have trouble figuring out what the other settings will do.
    I'll read through the online manual, but if anyone has already been down this road, I would sure appreciate some tips!
    Thanks again.[/quote]
