could anyone give advice on how to put 3 divx movies on one dvdwith menu. i have looked through the guides but couldnt find anything, especially on the burning and menu parts.
Just get Ulead DVD Movie Factory trial.
Re-encode the files with TMPGenc to DVD compliant with a low bitrate (use the calculator) so that they are each 1.35GB or less and then load em into Ulead and you should be all set. -
Originally Posted by rvl123
If these are full movies then the bitrate to achieve that size of file is going to be rather low. I recommend using 2-pass VBR at 1/2 DVD resolution to get reasonable results. Try puertorican138's CVD Templates and adjust the average bitrate to suit. Hopefull none of your movies are too long.
"Art is making something out of nothing and selling it." - Frank Zappa -
The KDVD gives UNCANNY VIDEO QUALITY at AMAZINGLY LOW BITRATES! get it from KVCD.net. As for the menus and shiz, just use DVDLab or TMPGEnc Author. I chose these 2 since they do not reencode the source video/audio. MAKE SURE YOUR AUDIO IS AC3/PCM/MP2!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
