When I convert my 16:9 DV footage to divx with VirtualDub I loose the pixel aspect ratio.
Before conversion I play the DV in mediaplayer and its widescreen(I see black strip at top and bottom in normal and fullscreeen mode).
When I do the conversion to DIVX and play it with mediaplayer (or other player) the avi is 4:3 and things does not look what I expect.
How do I preserve the 16:9, I though that codecs did not care about the aspect ratio.
I resized my video to 720 x 396 to get the 16:9 ratio. Now I can see the correct video on my computer.
I did it with a filter in virtualdub and in the Divx 5.0.5 with same result.
But is this the proper way? Anyone help?
I don't like the feeling cutting away a lot o pixels.
If I knew this I would never shot in 16:9 on my Sony TRV80.
And I heard that the width and height should be in a factor of 16 pixels. Meaning that 396 pixel is not devided even by 16.
Does this have something to do with the compression algorithm of the codec? -
Certain codecs (XviD and DivX included) need aspect ratios that are multiples of something. 2 is a minimum, but some are 8 or 16 (varies with codec/version). I believe DivX5 is multiple of 8. Multiples of 16 are safe for about everything.... and explains certain resolutions you see like 720*400 (not quite 16:9) or 640*360 (16:9 but ratio of 8).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Divx Aspect Ratio Change??
By gdb in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2011, 07:34 -
How do I create a DIVX w/correct aspect ratio
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Oct 2008, 10:16 -
Changing Aspect Ratio on wmv to divx conversion.
By steve_hawthorn in forum Video ConversionReplies: 7Last Post: 27th Feb 2008, 13:58 -
VDub/Divx - How to setup Aspect Ratio
By neomaine in forum Video ConversionReplies: 7Last Post: 6th Feb 2008, 17:05 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 12:53
