Well. I've got a .RM file, and I managed to get it into an uncompressed .AVI with TINRA (4.00GB!!) It was listed at somewhere near 60fps so I loaded it into VirtualDub to synch the audio and video together as the RM conversion tutorial suggests, since it was to be a temp file, I wasn't going to compress it, as it would go streight into TMPGenC to be SVCDd. Well VD failed about 3/4 of the way thru with some sort of Video I/O error. I also tried just using TMPGenC on the raw AVI and setting it to 30FPS, and it just gives a fairly small .MPG file and it's all black with no sounds or video. I'm having an evil time with this .RM file, but it's the only way I think I can get this particular episode of this anime. Any suggestions or help? Either reply here, or Privately to me. Thanks in advance.
Rob
Results 1 to 1 of 1
xmediarecode isn't handling this particular file very well
By pooksahib in forum Video ConversionReplies: 2Last Post: 22nd Jun 2011, 06:46 -
Prolem with 23.976 FPS AVI file
By ho1 in forum Video ConversionReplies: 3Last Post: 22nd Oct 2009, 11:50 -
60 fps to 30 fps conversion -- It looks terrible
By usps_postal in forum EditingReplies: 6Last Post: 18th Sep 2009, 21:09 -
Suggestions on PC spec for AVCHD file handling/render
By dicksibo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Apr 2009, 03:29 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35
