Hi, when i try to merge two SVCDs in TEMPEGs 'Merge&Cut' tab under 'Mpeg Tools' the first half of the merged film is fine but the second (where the first ends and the second begins) the audio is out by miles! This has happend on 3 SVCDs that i have tryed!What am i doing wrong
(in Newbie terms please
) What should i do
Use a program like Gold Wave. Load the original video into it. Cut out the video that is used in the first part. Save the rest to be audio input for the second part. Go back to TMPGEnc, load the second part video and the audio you saved from Gold Wave. The resultant video should be your second part in synch.
Hello. -
www.goldwave.com
And use www.google.com if you want to find tools in the future...
Merging mpeg
By drgt in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 06:19 -
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 16:00 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 10:50 -
Problems Merging DVDs
By npjs31 in forum Newbie / General discussionsReplies: 2Last Post: 29th Feb 2008, 03:44 -
Problems with merging to avi files
By mingul in forum Video ConversionReplies: 3Last Post: 6th May 2007, 11:06
Where can i get Gold Wave from
