Hi all!
Recently my brand new Pioneer 105 burner had to be returned (after 2 monthes and 9 successully burnt DVD).
I was thinking "well, bad luck..."
But on some other forums I read the post of a user complaining that a Princo DVD-R has broken his pioneer 104 drive !
Suddendly I got big doubts !
Can a princo (certified x4) DVD simply break my Pioneer 105 burner ? I mean is this technically possible ? It's a x4 drive and a x4 DVD !
I have the 1.0 firmware.
Thanks for your comments![]()
iMac 400 DV (So what!) - 512 Mo RAM - HD 50 Go - Panther
There was a problem with Pioneer 103 and 104 (a03 and a04) burners that using 4x media could screw up the drive (any 4x media, not just princo's).
This problem was fixed with firmware but the 105 was not affected.....burn away my friend.....burn away.
(disclaimer: I take no responsibility if you screw up your drive by "burning away"
"Weekends don't count unless you spend them doing something completely pointless."
Bartman 8)
Exploded DVD in Pioneer DVD Burner
By SE14man in forum MediaReplies: 1Last Post: 24th Apr 2012, 09:57 -
Fixing/Replacing DVD-burner (Pioneer 630-H) -how?
By tigrr in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Feb 2011, 17:20 -
Pioneer DVD-RW X162 External Burner ???
By blinky88 in forum DVD & Blu-ray WritersReplies: 4Last Post: 9th Aug 2009, 06:03 -
Pioneer DVR-543HS , is my DVD burner toast?
By stew182 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2008, 13:57 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43
