Is it possible to put a MPEG-1 file converted using TMPGEnc, onto a DVD Disc (that'll work on my DVD player) without having to re-encode it?
Cheers.
Yep, VCD resolution mpeg-1 at up to 1.85Mbits is valid for DVD. The audio must be at 48khz sample rate tho. Take a look here:https://www.videohelp.com/dvd and scroll down to the Technical info bit.
If you're lucky, you can even put the mpg file without any alterning directly onto a DVD ISO disk like mp3 or jpeg).If your player can do this, you save a lot of time,Try this first with a DVD RW.
I've got a Philips DVD-Recorder which plays anything I wing it's way, so maybe that will play it. I'll try on a DVD-RW first of course.
Thanks again. -
Any tips on how I should burn this MPEG-1 file to DVD-RW using Nero?
You can't use Nero standard if you want to make a DVD-Video that should work on most DVD Players. You must author it, www.dvdrhelp.com/author#dvd and www.dvdrhelp.com/tools.php#DVD%20Author
That's right for most players, but you can use NERO in ISO mode anytime, if your player supports direct mpeg files.I just tested that yesterday.
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 20:32 -
Help with Business Project - PDF/MPEG on a Disc
By mn072065 in forum ComputerReplies: 8Last Post: 19th Nov 2008, 21:44 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 07:09 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 05:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
