I am capturing some VHS tapes to my computer using the ATI 7500 card. I have done this before with no problems. For some reason I am not capturing sound. I know im connected properly because I can hear the VHS tape when it is playing. The sound is coming through my speakers. When I play it back, either on my computer or burned as a DVD there is no sound. Any ideas?? Thanks.
Using your control settings find the audio settings. You are looking for RECORDING AUDIO. If you are using Line In audio, it should be checked.
Hello.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
